On my 06 cl500 the other day the Keyless Go didn't work. I can start the car with the fob, open and close doors with fob, but cannot just open the doors with a pull? What is wrong?
The door opens when you pull twice? If so, you apparently have pushed one button for too long. Check the manual for key comfort functions
Now the fuse doesn't blow anymore but the car says key not recognized when I try to use the button on the shifter knob with doors closed and foot firmly on brake. Everything used to work! What is going wrong?
Everything used to work. The fuse for Keyless go kept blowing. Today I put a fuse in and it didn't blow. Now it says key not recognized. Doors lock and unlock so it isn't a battery issue
