95 E320 Coupe, 11 E350 4Matic P2
Hi everybody well my car wont even click when starting nothing at all just nothing its like its dead. I'm thinking its a fuse problem but I checked every fuse they all seem to be ok now i'm not sure where the Ignition fuse is or anything similar to that. doeas anybody have any idea???its a 95 E320 if anybody has pictures of their fuse box please post I need to compare.
thanks.
yes everything else works
stereo
lights
everything
the car jsut wont click. so if your thinking is it the battery well its not.
· BenzWorld W126 & W201 Host
1988 420SE, 2002 C180 Kompressor, 200 ML320
As everything else is working, you are probably suffering from one of four faults.
1. A imobalisor gone bad.
2. A bad starter motor.
3. A bad ignition switch.
4. A bad gearbox (tranny) inhibitor switch.
To test if the starter motor is O.K. there is a three pin plug against the firewall which if you unplug it and bridge the middle pin with the battery positive, will cause the starter motor to engage.
I have attached a pic of my W126. I know it's completely different, but it's just to show where abouts the plug is situated on your car. Where I have circled in red, the plug is on the inside of the firewall at that location. It is on this side on UK right hand drive models but not sure on left hand drive, so check both sides.
If the starter engaes then you have ruled out a bad starter motor.
Discussion Starter · #7 ·
It wasen't the fuses it was my alarm it was in Valet mode and somehow the Ignition Lock was activated and now I need to disable the ignition lock to turn the car on.
who would ever guess that this was the problem...
