02 ML320
Ok every time I wash my engine bay then try to start the ml it always blows the gauge and heater fuse.Does this happen to anyone else?I even washed it carefully making sure I didn't spray the fuse box area.
Black 2005 ML 500
No it is not normal. I even carefully pressure wash my ML exterior and engine.
There must be some wire that may have been pinched or exposed and is making ground, or maybe a loose connector that is letting water in..?
Good luck...
BenzWorld Elite Member
2004 SL55, 2006 Range Rover Supercharged, 2013 Infiniti M37
With the advent of the sophisticated electronics within our vehicles, I would strongly advise against "washing" the engine compartment of any modern day vehicle.
Brett
Good luck...[/QUOTE]
