A couple of times over the last 2 weeks, I've had the opportunity to use full throttle from complete (or nearly complete) stop. The transmission is in first with the engine pulling really strong and the engine cuts out completely instead of the anticipated upshift into second gear!
Obviously the engine revs have just tripped the over-rev limiter in the fuel pump relay... shuts the engine off instantly - I can tell you. This has occurred a total of two times recently and once last year/year before.
Never occurs except when it gets down into first and I have my right foot planted...
Has anyone else had this occur & what was the fix?
Mine is a stock 560 that runs smooth, quiet & strong. The transmission shifts well.. up - down - kickdown.. whatever..
Thanks & Cheers, MBL
