82 300SD fiwer, 83 300SD parts car, for now...
I'd like to remove the fuel tank from my 300sd parts car but I'm having trouble getting at it, is there a trick? It seems to be hidden carefully!
1965 220S, 1999 Volvo V70 (wagon), 2006 Ford Crown Vic Police Interceptor, 72 350SL 4 Speed
It's behind the front panel of the trunk. The fuel drains from the bottom, though the floor to the fuel line. The fuel level sender is under the back deck and needs to be unplugged. Then there is the fuel inlet.
`81 W123 280E, `83 W126 280SE, `85 W126 280SE, `91 W126 500SE, `96 W202 C180T, `99 W202 C220CDI
You have to remove that cover in the trunk that is hiding the fuel tank. After that you must disconnect all the lines going in and out of the fuel tank. The fuel sender (as wbain pointed out) it is under the rear seats and the hole that you can reach it (maybe) is covered by a plastic circular cap.
Good luck!
