1 - 16 of 16 Posts
1991 500 SL and 1993 600SL
The last 2 times I have fueled up, I would get home and the cabin would be filled with fumes! I can see that the pressure is so great in the tank that it leaks out the cap and if I release the cap, fuel GUSHES out and won't stop. What would cause this abnormal pressure?
Plugged vent line, or defective charcoal canister. Normally gasoline fume is vented to the charcoal canister.
Where is the vent line RKH? Pretty scarry stuff because I have to park it in my garage.
Don't park it in enclosed area until it is fixed.
Push the car outside and wait for a while before you start it.
Take a look at this : Êàòàëîã
Greek God of the R129
SL500-500SEL-190E
Do as RKH very well has said.
The problem is most likely is the number #8 it is a
check valve that works on pressure differential push/pull,
and #14 dumping fumes in the engine.
The charcoal canister is located in the left fender well.
Remove the left wheel, then the well you will find in there the canister to your left and the vacuum reservoir in the lower right.
Remove canister hose to see if it works up to that point.
If not go backwards, to #8 or clear fuel lines etc.
Regards.
aam.
1992 500SL, 1988 560SL, 1977 450SL, 1999 E320 4matic
Regards.
aam.
aam,
Humm...Is this a regular part of maintenance and when should anything be replaced or cleaned.
Carltwo
Discussion Starter · #9 ·
Thanks for your pointers guys, I'm on it tomorrow :)
300sl (r129),porsche 997, mercedes e250 cabrio (W207,280 clk (w209) rx270 lexus)
Regards.
aam.
Gro ,
what is #8 and#14 ?
My car gor the same problem?
thanks
bro, i always have petrol smell in the cabin when my car idle got into traffic jams...
do u have any idea? i notice that when the smell comes on , i turn off the (*) air con compressor switch and the smell goes off. also the car doesn't have this problem when cruising...I somehow felt its related to the vacumn but don't know where to start the troubleshoot.
Please help....
robinp, sounds like you have a problem with your charcoal canister. Please follow the link in my post #4
SL500-500SEL-190E
Before you get deep in $$$ try to replace the gas cap if the seal is bad you get the smell.
Regards.
aam.
bro, charcoal canister already changed . still the same
If you can smell the fume while sitting in traffic but not when moving, that means it is coming from the front where the charcoal canister is. Also means there is no blockage in the vent lines from the gas tank to the charcoal canister. The things to check then will be for loose connections of the vent lines etc. Also should check for fuel leaks around other fuel related components in the engine compartment like pump/distributer/injectors too.
SL500-500SEL-190E
Robin look at the RKH diagram on post #4 find the parts #8 and 14
That could be your trouble.
Regards.
aam.
1 - 16 of 16 Posts
