1982 300td wagon with 435,000 sold, 1984 300sd 230,000, 1980 300sd 113,000, 1983 300cd 260,000
I took out the fuel sender with my 1 13/16 sears socket and now it is sitting on the bench. Do you pry it apart or does it unscrew. Since it is over 200 bucks I figure i better be nice to it. This is out of my 123 300tdt wagon. Thank you
1985 300CD
There is a nut at the bottom that needs to be removed. You can slot the tip of a screw driver. I used the tips of snap ring pliers and twisted it off. Then the whole tube unscrews. Be careful when you pull it apart. There are 3 thin wires that you don't want to break.
You can see the threads where the tube unscrews from on this pic. The center shaft is what the nut is attached to.
This pic shows mine before I repaired the broken ground wire.
