Thanks a lot! So I started my investigation and here is where I stand so far:
1. Fuel pressure at rail with ignition on, engine not running: 50PSI, slightly higher with engine on idle.
However, turning off engine will see pressure drop immediately to 45PSI, then rising again to 55PSI and then stable
2. I have pressure in the fuel tank, not vacuum. This becomes obvious when unscrewing the fuel cap. Pressure is building in the tank only after a few minutes of engine running .
3. Checked purge valve: Disconnected incoming hose, no pressure ("Woosh"). Checked hose to canister connection with vacuum/pressure tester (engine off): open connection, no vacuum, no pressure. Checked purge valve function: OK
So I guess the issue is somewhere between the tank and the canister. Vent valve?
Any suggestions?
Thanks again
