1 - 8 of 8 Posts
2013 ML350 4matic and 2003 C240 4matic
When testing the fuel pressure, what should be the reading? When accelerating hard (especially when it is hot out) my car starts to jerk and hessitate a little. I am wondering if my fuel pump is weak as it does it around 3000-6000 rpm. I have a 2003 C240 4matic.
Marc
[email protected]
How many miles are on the clock? When you get north of 100K, you can have catalytic converter troubles.
117k. Is there a way to test the catalytic converters? I am embarrassed to ask, but I have never dealt with them
There is no sure way to tell besides having a mechanic remove the exhaust pipes and check the pressure, but if shake the exhaust pipes and hear noises, or smell "rotten eggs" at the tailpipe, those, along with poor performance are tell-tale signs.
2003 C230k
im having the same problem, ive narrowed it down to vapourlock, although it could be more vapourlock is begginging my symptoms, your fuel cooling uinit could be down
2003 C230k
cats are a grey zone, and very expensive. a potential test could be a vac test. but like in rodneys post, there are physical signs as well
Another easy check for bad cats is to make sure they aren't glowing red (check them on a hot engine in a dark garage). Also, you can use an infrared temperature sensor. I am not sure how hot they should or should not get, but they shouldn't be significantly warmer than the exhaust manifold or adjacent exhaust pipes.
1 - 8 of 8 Posts
