1986 560sl,1995 e320,1999 Buick Le Sabre
Does the O ring(Green One)go under the plastic boss that connects
to the head???
1981 380SL - Lorinser bodykit w/16x7 LOs - AKA "Frau Blau"(Lady Blue)
Hey 17th,
Welcome to Benzworld. We need to know some more info. in order to answer your question. Please go to the user CP and fill in your profile.
If your 560SL has the same injectors as mine, the o-ring fits on top of the four tabs of the holder, which fits into the injector port. But I don't know if it is the same.
Bandit
O ring
After you pull the plastic boss that the injector sits in,I think the (Green O ring sits on the bottom of plastic boss that fits into the HEAD??Yes NO
O ring
Yep thats it.Thanks a lot.Now all I have to do is pull them out with out
the plastic breaking all to hell.
Take a vacuum cleaner and a small piece of 1/2" cpvc pipe and some duct tape. Put the pipe in the end of the vac hose and tape it up with about 6" hanging out. Then use that to stick into the injector port, because you 1) aren't going to get the injector holders out in one piece and 2) probably will drop all kinds of crap down in there from the intake area. Trust me, I know.:thumbsup:
