Do you guys use a fuel injector/fuel system cleaner? If so, how often and what brand?
It has always been. No car or truck since the early 1900's has ever had pure gas/diesel from a retail pump.LZOM May be they do now
LOL, no, it doesn't.Keeps all the gum away from internals
Got a source for that?The modern one does clean up the injectors, and cures lumpy idle and lack of power. Proven.
Because thats not possible in the US. There is no defined "grade" of fuel for diesel. Stations that display "premium diesel" are the same "grade" as jo-blo corner fleet fueling station down the street.So as an alternative, if you have the symptoms described and you can get premium grade fuel, run on that for a couple or three tankfuls, or longer of course - it'll cost about €/£/$7 more than "regular" or low-grade fuel for an average tankful, and it might well solve the problem.
Why not?
Sorry, thats bunk. Diesel of today is far better than what was around in the 80's. It has less sulfur (a contaminant), less free carbon (better refining, reducing sludge inside the pump) and far less water contamination (the reason behind GM's 350 diesel downfall).The Bosch shop that did the work strongly recommended using Stanadyne additive to make today's diesel fuels more like they were when the car was built.
