1982 300td wagon with 435,000 sold, 1984 300sd 230,000, 1980 300sd 113,000, 1983 300cd 260,000
I had the two hoses replaced on my 300sd today and I was wondering what the extra hose is. The one with the pressed on fitting is the supply but the 5/16 next to it is what??? Would that be the return or is there a seperate return up above? Thank you. 1982 300sd
1983 300SD 169k miles
return line
1986 Euro 300SEL
There's a line from the tank to pump #1 (on a 2 pump system). Then from pump #`to pump #2, then from pump #2 to the filter, then from the filter to the front of the car, with the accumulator sitting up there with the thin line that tees off it. In a one pump system, take out the second pump and the first pump connects to the filter.
I'm pretty sure there's only the one IP on a 617. Again, I'm new with this stuff and could easily be wrong, but the fuel system is one thing I'm fairly well versed with. The WVO mods have necessitated re-routing fuel lines on a few occasions, (and changing out the IP once... whoops).
CH4S Admin , Outstanding Contributor
1985 500SEC, 1991 190E 2.6.
* 47-700 - Removal and installation of fuel tank
* 47-705 - Removal and installation of fuel expansion tank
* 47-710 - Removal and installation of immersion tube indicator
* 47-715 - Operation of immersion tube indicator for fuel gauge
* 47-720 - Operation fuel tank positive and negative venting system
Is this the file you needed?
