1 - 1 of 1 Posts
Fuel gauge stopped working after fixing bad pixel
After following threads here on how to fix time/temperature pixel on the IC unit, I managed to got myself in a much bigger problem: my fuel gauge stopped working all together. The needle stays wherever I left it after my unsuccessful attempt on fixing the pixel... well, the temperature display improved a bit but the time display did not. Fuse?
I hear some noise coming from that side whenever I turned off the ignition switch. Also, I managed to burn the bulbs the main(center) display and took off the bulbs from both the temperature and the clock display and put them in place of the center display bulbs.. and should be getting replacement from the $tealer tomorrow. I could not find them at autozone. Do those bulbs come out of the socket because I could not remove mine in any of them or do we have to replace the whole thing...if you now what I am talking about.
1 - 1 of 1 Posts
