cual es el problema? No esta marcando bien?Hello good I have a problem with the gas gauge when it gets full pretty crazy. Where is the fuel level sensor, to dismantle it.
The level sender is part of the pump. One of the little contact fingers probalyHello good I have a problem with the gas gauge when it gets full pretty crazy. Where is the fuel level sensor, to dismantle it.
You should first read the stickies on this forum and also update your profile.Hello good I have a problem with the gas gauge when it gets full pretty crazy. Where is the fuel level sensor, to dismantle it.
I had this exact same problem on my 98 ML320 -- started happening sometime last year -- had it happen off and on for a few months, and then mysteriously the problem went away. No idea why.When I fill up the tank, gauge drops down and stays there showing Empty until the engine uses about quarter of tank. Than it works fine, but at the end can show empty and after I restart the engine it shows about quarter tank left. It drives me nuts, but compare to cost of the sender plus headache of removing the back seat and removing fuel pump-setting the day meter and watching the mileage is nothing.
agree 100% i used techron and after a week fuel gauge came back to normal!!Sergi
tart mechanical work, this could be some pollution on the fuel level sender that can be disolved with a standard FI cleaner, eg Techron. It's worth a try.
See this thread: http://www.benzworld.org/forums/w208-clk-class/1377883-fuel-sending-unit.html
