Assuming that the fuel gauge returns to zero when you switch the ignition off, the probl...
Assuming that the fuel gauge returns to zero when you switch the ignition off, the problem is probably within the sender unit in the fuel tank. I haven't removed a sender unit but apparently it can be removed and refitted from within the luggage compartment - it isn't necessary to remove the tank. Before doing this, it is suggested that 8 litres of fuel be siphoned from the tank assuming it to be full.
JohnG
JohnG
