I have a 1987 300TD its time to change the fuel filters and was wondering if its a project that is pretty basic and i can do myself to save some cash, or is it something I should have a shop do? I do all the oil changes my self to save cash so if this is something I can do also it would be great. any advice or step by step instructions would be much appreciated. Thanks!
1990 300E 2.6L 144K
Easy
I did it myself and I'm 16, you can do it.
Andrew-
Edit: You will need a metric socket with extension set to get cover off, then two wrenches to "unscrew" filter nuts. Make sure you open fill tank or gas will be misted into for face. Make sure you use new washers (the one I bought came with them) before you put the cover back on, obviously check for leaks. good to go.
1989 300E 125,000 miles, 2005 Acura TL, 2011 Hyundai Elantra Limited
Fuel Filter
Yes, it is easy! While you are down there, check out the rubber hose that leads out of the filter to the metal fuel line. This is hose that over time tends to crack and leak! It is a custom hose with special fittings you can replace by ordering online for anywhere for under $30 in most cases. Make sure you do this procedure in a well ventilated area and have a catch pan in case some gas leaks out during this process.
Cheers!
