I have just bought a 1985 190.
The car is a 2.0l automatic, with a Pierburg 2E-E carb.
The car will only start if I disconect the electrical lead to the Fuel Cut off Valve, which sits below the carb body.
Does anybody know what this devices does ?
can you repair it, if not does anyone know where replacements might be found ?
UK based.
BenzWorld W126 & W201 Host
1988 420SE, 2002 C180 Kompressor, 200 ML320
That valve also controls the fuel/air mixture. When you turn the ignition off, it shuts the fuel off.
I think is is a sealed unit and not repairable.
You could try http://www.dronsfields.co.uk/ for a secondhand one.
Thanks, Spanners
I presume as it has stuck on closed, driving round with it disconnected until a get a replacement is OK.
I would think so, the only possible side effect is probably the engine running on when you switch it off.
