1 - 1 of 1 Posts
I have been getting a lot of PM's from people who are requesting the PDF for the FSS reset. I am posting it here again and the text is also copied here for those who are for some reasons unable to get it.
AP00.20-P-0042RT Reset service indicator 18.3.05
MODEL 251
A1p13 Multifunction display
A1s3 Trip odometer reset button
S110s1 Scroll forward/back button
S110s3 System selection button
S111s1 Buttons + and - for setting
specific functions and volume
control
P54.30-8579-06
Adjust
1 Turn key in electronic ignition switch control
unit to position " 1"
2 Press the system select button (S110s3)
repeatedly until the basic display (kilometer
reading display or temperature display) is
shown in the multifunction display (A1p13)
3 Briefly press trip odometer reset button (A1s3) 3 i A signal tone sounds and the voltage
times. display appears in the multifunction display
(A1p13).
4 Press lower scroll forward/back button (S110s1) i The "Service menu" appears in the
multifunction display (A1p13).
5 Press buttons + and -, setting of specific
functions and volume control (S111s1)
repeatedly and select "Confirmation" menu item
6 Press lower system selection button (S110s3) i "Confirmation" appears in the multifunction
to confirm. display (A1p13) and the menu item "Complete
service" is shown against a sight bar in the
background
7 Press lower system selection button (S110s3) i "Service confirmed" appears in the
to confirm. multifunction display (A1p13).
8 Press the upper system selection button
(S110s3) repeatedly until the "Service menu" is
9 Using the + and -buttons, setting of specific
functions and volume control (S111s1) select
the menu item "Special work"
10 Press lower system selection button (S110s3)
to confirm.
11 Using the + and -buttons, setting of specific
functions and volume control (S111s1), select
menu item "Service 3"
12 Press lower system selection button (S110s3)
to confirm.
13 Select the button + and -, setting of specific i "Standard oil" or "Oil quality 229.5".
the specification of the engine oil used
i If only one oil quality is approved for the
engine, no oil selection is possible.
14 Press lower system selection button (S110s3) i The message "Item confirmed" appears in
to confirm. the multifunction display (A1p13).
15 Press the upper system selection button
(S110s3) repeatedly until the basic display
(kilometer reading display or temperature
display) is shown in the multifunction display
(A1p13)
16 Turn key in electronic ignition switch control
unit to position " 0"
1 - 1 of 1 Posts
