I have 6 of these new in their bags. Genuine Hirschmann aerial with the deer logo on the tip. This is the early version through 1983 models. It uses the smooth cable, no teeth. $70 each delivered in the U.S. These must ship in a cardboard box or be protected between cardboard. Most boxes are way over sized for these so I will see about buying hard flat mailers or cutting boxes up.
If you slide yours out(back off nut and turn radio on) and it has dull ridges on it that is just where the gears dug into the smooth cable. You can also find cheap light chrome MTC/URO versions that run $25 but I'd be surprised if one of those really lasts if that's what you're after.
