1978 240D sedan, blue, 4-cyl, manual (parting) and 1990 300TE 4matic wagon, automatic, with A/C
I have a factory tow ball/trailer hitch setup on a European import 1986 Mercedes Benz 250D wagon. The ball is integral to the unit, and doesn't fit my 1 7/8" trailer hitch (my machinist says this ball is about 75 thousandths of an inch larger). So I guess it is not 2" either. Point is, it's nice but I'm not sure how I can use it, even if I change my trailer hitch.
So if someone would like to buy it, I will probably sell it.
My setup is like in pictures 3, 4, 5, 6 of this post:
http://www.benzworld.org/forums/w123-e-ce-d-cd-td/1546701-booty-needs-triler-hitch-wanted-factory.html
I'm trying to reach that poster also.
Thank you.
1967 250 SL, 1965 300SE lang
FYI
Trailer balls in the United States are typically 1 7/8" (47.6 mm) or 2" (50.8 mm). Almost everywhere else in the world trailer balls are 50 mm (1.97") (ISO Standard). At U-Haul I see trailers with couplings that accomodate both 1 7/8" and 2", so I'm surprised that you have a coupling that REALLY wants 1 7/8".
If you have the option of changing the trailer tongue / coupling on your trailer from 1 7/8" to 2", I would think that would work well.
