This is a set of four BBS RC307 wheels. All four have been checked with a dial gauge and are straight both radially and axially. There are imperfections in the surface on all four wheels, the worst is the fourth wheel (far right in the photo) which has scrapes on the face and also some curb rash on the lip, opposite from the valve stem. These wheels are very light weight, each of the four weigh between 19.0-19.5 pounds on a calibrated digital scale. I was going to use them as track wheels for autocross but never got around to mounting tires on them. They would be perfect for any kind of track use.
Please see detailed photos below, there are close-up pictures of the cosmetic issues.
These are genuine BBS wheels (not OEM VW/Audi) and require BBS PFS centering rings (available from BBS or aftermarket vendors) to fit your specific application. The PFS centering ring bore on these wheels is 82mm and I believe you can obtain rings for up to 72mm hubs. For Mercedes, a 66.56mm centering ring is needed. The wheels can accept either M12 or M14 cone-seat lug bolts. I have a set of M14 x 1.5 x 30mm cone-seat lug bolts that I can include free, if they happen to work for your application. Most Mercedes through late 1990's will need M12x1.5x27 lugs. Center caps are NOT included, these are also available from BBS if you want them. Since I was planning to use the wheels on the track, I never bought caps. The wheels should fit most Mercedes W124, W201, W208, W210, R129 chassis and possibly others as well. I do not know what VW or Audi models they will fit, or what other makes/models may fit. Please confirm that your vehicle has the proper bolt pattern and can accept the width/offset.
Click here to view a catalog with the BBS part numbers for the various PFS centering rings, and center hub caps.
$750 USD plus shipping, PayPal is ok.
Shipping to west coast is roughly $100, to east coast is roughly $150, email me your zipcode for an exact quote. Free local pickup. If you have a shipping account and can issue a call tag, that's fine too.
