Another one I haven't had luck selling on Ebay.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=8056493803
If your car is not a 2.3-16v, this head will not work for you. Unless you want to change out the pistons,oil pump,rods, exhaust, intake , etc etc
Discussion Starter · #5 ·
The head was gouged from a valve seat dropping into the combustion chamber, I then had the head repaired and pressure tested. It was not found to leak at all
Discussion Starter · #7 ·
Well....I spent $500 to rebuild and port the head so no less than $750 . It comes with the cams , cam gears, valve buckets and shims etc .
