I posted this on the other MB site, but had many response of the same problem, but no solution.
Does anybody here have an idea of what's going on? The problem is when I take meduim turns at very low speeds (1-3mph), the front tires hop/skid and scutter as if one wheel wants to go staright and the other is turning. This problem is MUCH worse when the ground is wet or very cold.
The problem seem to have started after I changed the pads to #1's.
I've changed the steering damper and had it aligned, but that didn't fix it. Any ideas?
