21 - 24 of 24 Posts
2002 ML55 AMG, 5.5 liters
An 2003 ml 55 would in had 285/50-18
Circumference is 29.2. & 11.2 wide
Your 275/45 -20 =
29.7 and 10.8 wide.
So It seems that tire size should be fine.
You check for a broken rear spring? If I remember correctly you recently were looking to change them?
Yes, I replaced rear springs with a set I bought on ebay. The shocks where bad so I replaced them with my bilstein shocks. The rear now rides a little rough compared to the OEM shocks but I can live with it and the bilstein really shows when I'm off road.
W163 and General M Gremlin
Discussion Starter #22
The correct spring set (for ML55s) ?
Strut setups, from my limited knowledge, had different 3 color dots on the springs themselves, for each level (more or less) of W163s and the ML55s had shorter strut setups (maybe 1"-1.5" vs. the other levels) and of course, to compensate for the hefty spare in the rear compartment.
Your KYBs up front:
Same as what member David recommended and reported on:
Humm,
Lowered and bouncy still? and you swapped to KYBs too.
Interesting. We have none of the issues reported by many past members after dropping the ride height - City driving too.
Another issue? perhaps the torsion bar bracket (mount support)?
For our rear setup, the shocks of choice were the Bilstein B6s.
Your KYBs up front:
Humm,
Yes I got the correct struts off ebay with matching 3 dot colors like the one that came with the truck. This vehicle was raised very high by an inexperienced mechanic to avoid the rubbing of the tires to the frame. I didn't know what cause the bouncing at first so I had to replace two front shocks just to fix the problem. Thanks to this forum I quickly realize I had to lower the truck to return it to its proper handling. At 30mm ride height I almost don't want to adjust further because the truck drives much much better now. But I will try to go 28mm and see whether the rubbing returns. I'm also using the Bilstein B6 at the rear.
Discussion Starter #24
And when you adjust, (as Im sure you already know), dont just go with equal depth check adjustment at the adjustment hole (due to the age of these suvs) - you may need to adjust the "screw in" heights on each side accordingly, to match the equal ride heights at the wheel well.
That's why I went with B6s on coil-overs vs. oem ML55 struts. Ive driven my colleagues 02 ML55 and he has driven mine with this setup - he found the CO setup much more comfortable (and with a lower ride height vs. his) over his amg. His wife doesnt like riding in his, but she'll sit in ours.
I have a spare set of the ML55 rear struts I plan on installing (to test) in my daughters 01 ML430 when the time comes.
If it doesnt pan out, I'll set hers up with COs and maybe go a tad softer on the coil spring rate and B6s.
21 - 24 of 24 Posts
