1981 380SL
The front speaker panel along the dash(drivers side) is loose along the top edge - it drops down and is held in place by the bottom edge which is still connected to something. I do not see any type of clip / or way to secure it on the top of the speaker panel. Anyone know what part is needed to hold the top in place or a fix to the problem. I would like to avoid gluing it in place, if possible. Thanks, Andrew
1972 350SL Auto
If it's like my '73 350SL two small screws hold it at the bottom. There shoule be two metal strips which slide into the grill on the inside. These hooke under a bar connected across the top two screws retaining the speaker. Hope this helps.
