1984 190D
I have a nasty grinding sound coming from my front right wheel when I brake. Any ideas on the culprit? No indicator lights are on. From what I've read it could be the pads, rotors, or wheel bearings. Any advice as in time, cost, and difficulty of the job would be much appreciated. Thanks!
1984 190D
I don't think my car has ABS. It's an 84 2.2l. The wheels are stock but I did just switch from my winter tires and rims. The snow tires are on rims from an 87 MB 500 series. They are a lot wider than my stock rims. Could that have caused the problem?
1991 300SE
turn0267 - 4/10/2006 10:43 AM
Only thing I can think of is....take the wheel off and remove the caliper to inspect it and the pads/rotor. If it only happens when you apply the brake, then it sounds like worn pads grinding into the rotor. A bearing problem would usually announce its presence when turning corners. My $.02
Good luck.
