1 - 12 of 12 Posts
1978 U900 406
Hi all, been awhile since i last posted.
Any chance anyone could measure there plate that the schmit attachments hook onto. I'm going to attempt to make my own, the most major measurement i require is the distance between the recesses that hooks go into.
Many Thanks
liam
2015 Rubicon Unlimited (Let the shame be upon me!)
Long shot but is the plate the same on the U500? I have drawings for the plate and the hooks for the U500.
1978 U900 406
i am assuming this must be the same as the u900 plate. th biggest problem is i am still missing the parts such as the hydraulci pump protector plate so this makes it alittle harder to fasten anything to the front of the unimog.
1978 U900 406
Anyone have any of the measurements for the u900 front plate, im pretty sure that the plate for the newer mogs wont work, if anyone has any close up pictures it would be much apprecieated
many thanks
liam
BenzWorld UNIMOG statesman
Unimog 404.1 Diesel (sold :( )1995 LMTV 1078
..if anyone has any close up pictures it would be much apprecieated
many thanks ...
hmmm.... there is a thread in here of pics of plates if Im not mistaken. a Truktor thread. Suggest you search using key words of something like...
Truktor Plate pics
1978 U900 406
Many thanks Truktor, those pics have helped alot. Any chance some one could tell me the width and height of the lower part of the anbauplatte for u900.
liam
1978 U900 406
Sorry to bother everyone again, but could someone tell what size the holes are on the lower schmidt plate where the stays attach up to the pump guard, as i am in the process of writing down what i need so i know what to buy tommorow while im in town.
Many Thanks
'79 Flat Bed 406
Haven't actually measured the holes as I have the Schmidt 3.4 plow hooked up to it at the moment, but the bolts I use are 7/8" so the hole size is at least 1".
Here are some pics of the U900 schmidt plate I got form the net.
The lower pins are 30mm on the pump guard and on the schmidt plate.
The V notch center to center on my u900 is (24 5/8 in) as measured and the large plate is (33 13/16) X (13 7/8) X (3/8 or 10mm thick).
My 24.625in (625mm) is very close to 24.8in (630mm) posted earlier in b101uk pic, the difference could be in the way I measured.
Hope this helps.
1 - 12 of 12 Posts
