1 - 1 of 1 Posts
The Wife and I noticed right after we bought our C240 that the Front Passenger Window is Very Tempermental. I thought that the solution was on the door itself. There is a hinge in the center of the door that was very loose, and I thought maybe the problem lied there. I tightened it and it worked a couple weeks later it now doesnt work. Because there is an Airbag in the door I dont want to just start pulling stuff off the door to see if its a loose connection internally.
Any thoughts on this problem?
Oh.... if the window doesnt work it wont work on the door switch or the drivers switch.
Seems to start working thought if you slam the door shut.
1 - 1 of 1 Posts
