1 - 18 of 18 Posts
I have search on this forum on this issue and cannot find a remedy or a possible fix to it =(
I have been getting this error message ":
"Low Beam R, check lamp"
My passenger side low beam suddenly failed to turn on , I have since changed the bulb to a brand new h7 non hid one still not working!I even tried to plug it in both ways still no luck!
The high beam works on both sides , and the left front bumper marker is burnt out or not on either.
Can someone please direct me to what can possibly be wrong:crybaby2:. Thank you !
This is a 00 s500 airmatic suspension.Please help so I can drive my car at night
Thank you in advance!
2000 and 2003 W220 S500
If you have a standard Halogen, the proper bulb is an H 7.
(If you, in fact, don't have halogen the other bulb number as well as every other bulb numbers are below after the instructions.)
Get a flashlight; it can be dark.
Depress top tab on black plastic cover and remove.
Remove two wire plug from the rear of the old bulb and move aside.
Move the spring clip down and over and swing out of the way.
Remove the old bulb.
Using rubber gloves, open new a H7 bulb package so as not to get skin oil on bulb.
Insert the bulb into housing with tab in correct slot.
Move the spring over the bulb and engage it in the slots.
Reconnect the two wire plug.
Replace the black plastic housing.
Check the lights for function.
All this took about 10 minutes the first time and 5 after that! Good luck!
The bumper light replacement is on the stickies as a video.
2000 MERCEDES-BENZ S-class (With HID (high intensity discharge) headlamps)
Low beam headlamp
HID-D2R
High beam headlamp
H7
H7ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
H7XV XtraVision Halogen Upgrade: Up to 20% Brighter
H7CB Cool Blue Halogen Upgrade: White Hot; Super Cool; 100% Street Legal
H7LL Long Life Halogen: Lasts two and a half times longer
Parking light
2825
Front turn signal
2357A
Rear turn signal
1156A
1156AST Silverstar Signal Lighting: Complete the Look: Crisp, Clean, Style
1156ALL Long Life Upgrade: Up to twice the life of the standard lamp
Tail light
5007
7225
Stop light
LED
High mount stop light
%COM
Fog/Driving light
H1-55W
H1ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
H1XV XtraVision Halogen Upgrade: Up to 20% Brighter
License plate
6418
Back up light
7506
7506LL Long Life Upgrade: Up to twice the life of the standard lamp
Front sidemarker
2825
Rear sidemarker
5007
Glove box
6418
Step/Courtesy light
6411
6418
Zotye Auto 1.5T T600 2016
It may be the control unit, best way to check is to swap the control units left to right and see if the problem moves to the other side. If it does then change the bad control unit.
Low beam headlamp
HID-D2R
High beam headlamp
H7
Parking light
2825
Front turn signal
2357A
Rear turn signal
1156A
Tail light
5007
7225
Stop light
LED
%COM
Fog/Driving light
H1-55W
License plate
6418
Back up light
7506
Front sidemarker
2825
Rear sidemarker
5007
Glove box
6418
Step/Courtesy light
6411
6418
According to EPC it should be Xenon but without the vin # I cannot be 100% sure.
hey guys its the 2000 s500 with regular halogen so problem not solved yet. replaced bulb stoll the se thing ! where to go from here? please help!
Any expert can please help me out on the usual fix or things to look at for this . This is not a hid modern with regular halogen so the answer about did not help unfortunately!=(
Send me your vin # so I can look at your system.
2004 (w220) S500 & (R230) SL550 2007
DON'T ASSUME
Sometimes a new bulb is defective, right out of package
It has happened to me.
Swap left & right bulb which is known to be working and see what happens.
It is a proven method and works well in diagnostics, simple but effective.
W140 S500 , W220 S430
same thing happen to me , i ended up replacing my headlights with updated projectors from ebay and its been working fine, most likely something with the headlight assembly like the previous post , the control module
Discussion Starter #12
Ok but mine does not have the control module as it is the NON HID model! Correct me if I am wrong thanks.
Discussion Starter #13
Hey there my vin is WDBNG70J3YA098299 2000 S500 HALOGEN LIGHTS WITH AIRMATIC SUSPENSION . PLEASE HELP =)
According to the data card for your car which I just looked up with your vin # the car was built with Xenon headlights;
Название val
fin WDBNG70J3YA098299
vin WDB2201701A098299
whc WDB
chassbm 220170
chass_ident 1A098299
type 220
subbm1 170
subbm2
auxiliary_drive
body 00000
body_code
delivery_date
engine 113941 30 157847
front_axle1
front_axle2 05388552
heater
interior 235A
lights BOSCH
model_idx 0
odometer
order_num1 0070404188
paint1 366
paint2
paint3
paint4
paint5
platform
production_num1
production_order_ref
rear_axle1
rear_axle2
release_date
retarder 2 000110
rims
service_num
steering
trailer
transfer_case
transmission 722632 01 925385
vin_dc NG70J3YA098299
vinwhc
winch
wiper
Code Текст
231 Unknown
249 AUTOMATICALLY DIPPING INSIDE REAR VIEW MIRROR
275 MEMORY PACKAGE (DRIVER SEAT, STRG. COL., MIRROR)
349 Unknown
352 COMMAND
414 ELECTRIC TILT/SLIDE SUNROOF IN GLASS VERSION
461 INSTRUMENT WITH MILES IND. AND ENGLISH LEGEND
494 VERSION FOR USA
524 PAINTWORK - PRESERVATION
540 ROLLER BLIND, ELECTRIC, FOR REAR WINDOW
551 ANTI-THEFT/ANTI-BREAK-IN WARNING SYSTEM
600 HEADLAMPS - CLEANING EQUIPMENT
612 XENON HEADLIGHT
634 DELETION - FIRST AID KIT
636 DELETION - WARNING TRIANGLE
668 PACKAGING FOR SHIPPING VEHICLES WITH TIE-DOWN HOOK
673 HIGH-CAPACITY BATTERY
733 Unknown
772 AMG STYLING PACKAGE-FRONT SPOILER, SIDE SKIRT
774 SHELL MODIFICATION FOR AMG-WHEELS
792 Unknown
800 AEJ 06/1/M/X
810 SOUND SYSTEM
873 SEAT HEATER FOR LEFT AND RIGHT FRONT SEATS
875 HEATED SCREEN WASH SYSTEM
883 CLOSED AID FOR DOORS AND TRUNK LID
230A LEATHER, 2-COLOR
366 Unknown
235A LEATHER MUSHROOM
It is possible that a previous owner has replaced the Xenon with Halogen but why would anyone do that?? A couple of pictures of the back of the lamp unit would help a lot.
Discussion Starter #16
It is definetely h7 non hid and i have replaced the bulb already so I know =) I can put up some pictures too. So what is the next step that I need to do?
I really need pics to advise further.
1 - 18 of 18 Posts
