This is a common problem on the W140. Probably the most common problem.<br> <br> 1. Re-boot the 'system'. Remove fuses #3, #6 #9 & #11 from the trunk fuse box. Count to 10 or 20 and put them back in. Actually, not all of those are necessary to remove, but those 4 cover the bases. This will often cure the problem for many months.<br> <br> 2. If the fuse trick isn't working for very long any more, then replace the pump. It is in the trunk, just forward of the LR shock absorber tower. Just start removing the trunk liner parts starting at the trunk sill, then tail lights, then floor, then sides, then the forward piece exposing the pump. Disconnect the Bose radio (above and to the left of the shock tower) and slide it out to get the pump out. <br> <br> New pumps are about $700 at the dealer or rebuilts are available from http://www.programainc.com/ for $260. <br> <br>
