1 - 8 of 8 Posts
yes, i have done my research on this topic [:D]
can anybody give me some instruction on how to remove the front bumper?
i need to replace my halogen headlights with bi-xenon headlights before i take it to dealer to reset the computer setting. thank you.
E320 W211
I was searching for help on this as well. The only thing I found that may help was a post on mbklasse for the C-class. Looks simple enough, but I am just too lazy to do it. I've found somebody to do the install, just waiting to get the lamps.
SL550
Perhaps my recent posting on the SLK R171 forum will be helpful to you.
http://www.benzworld.org/forums/forums/thread-view.asp?tid=1207253&posts=6&fid=27
SL550
Fender/bumper attachment point...
Has anyone removed the standard front bumper from a W211 E-Class? I think I have located all of the fasteners but I am having problems at the point where the bumper cover attaches to the front fender. I peeled back the wheel well liner and removed the sheet metal screw holding the bumper to the fender. There seems to be a metal bracket popped over the seam between the bumper and fender (on the inside). Removal of this bracket is not obvious.
I am trying to mount the license plate bracket without drilling holes directly in the front surface of the bumper. I want to put a metal backing plate behind the bumper cover at the top edge of the mesh grille area. I could probably make do without removing the bumper cover, but, I think a more professional installation will be possible if I can figure out how to disconnect the bumper from the fender.
SL550
Successfully removed the bumper...
It took some time to understand how the bumper cover was secured to the very front edge of the fender. I did manage to remove the bumper without damaging anything. But there were plenty of times when I regretted starting this project.
I will post some photos in the next couple of days.
E320 W211
Finally somebody has attempted this. Yes please do post pictures.
I have an appointment to get the lights installed, but UPS damaged the light during transit and I don't know when replacement will arrive. :(
wow~ how did you do that?
i tried it numerous times to remove the clip, but i just couldn't do it. please...please post some pictures with instructions. thanks.
SL550
I started a new thread with a "how to" for removing the front bumper. I included several photos detailing the bumper/fender seam at the front of the fender.
http://www.benzworld.org/forums/forums/thread-view.asp?tid=1209573&posts=1&fid=18
1 - 8 of 8 Posts
