Some time ago several people on the forum were lamenting about scratched and damaged front bumpers. I decided to remove my bumper and take it in for repairs.
The front bumper is held in place by four screws securing the grille (resist the temptation to remove these first), two bolts on each side attaching the side top edge to the fender, two sheet metal srews securing the plastic wheel well shield, and two nuts in the corners of the grille attaching the bumper to the frame. You also have to remove the plastic panels below the engine compartent. You do NOT have to remove the headlights.
Here's the steps to remove the SLK350 bumper w/AMG Package. The standard bumper and SLK55 bumper should be similar but may vary in some details.
1) Remove the first two plastic panels below the engine compartment. The second panel should be removed first. It is held in with six sheet metal screws with an 8mm hex head. The forward most panel is held in with seven of the same type screws.
2) Disconnect the side marker bulb sockets on each side.
3) Disconnect the fog light cable connector on each side. You will have to cut the electrical tie on the passenger side.
4) Pop the temperature sensor out of the rubber grommet in the bumper.
5) Remove the two screws on each side securing the plastic wheel well shield (10mm hex).
6) Remove the two 6mm bolts (10mm hex head) attaching the bumper to the front corner of the fender.
7) Remove the two 6mm nuts (10mm hex) attaching the bumper to the frame directly in front of the car. If you can figure out how to pop out the grille you can access these nuts from the front of the car.
8) Remove the four 6mm bolts holding the grille in place. Remove these last otherwise the bumper may fall off while you are under the car removing all of the other screws.
9) Gently work the bumper free.
It took me a few hours to remove the bumper including the time to figure out how to raise the car high enough to get some jack stands under it.
If you remove the grille (AMG mesh style) be careful not to break the plastic retainer clips. I will take some photos of the car without the bumper in place and point out the areas where the bumper is fastened to the car.
