300SD
What is the easiest way to remove the front bumper on a 300D? I see the bolts on the bumper shocks that need to come out, what else?
2007 S550
That's about it.... 8 bolts, 4 on each shock mount then it will slide straight out towards you. The shock body slides up into the frame rails so when you remove the bumper you will have to slide them back out before it comes free. It might be a little stuck on the studs at the shock mounts but work it side to side and keep a good grip on it. It probably doesn't weigh as much as it looks like it should but it can be awkward when you are pulling and it suddenly lets loose. :(
