G
I am getting a 19' carlsson 1/6 evo. I am confused if I should get 19x10 for the rear or 8.5. I know if i get 10, i need to modify the fender and i don't know if it is worth it or not. When you used your 19' alstadt wheel? what is the spec for the rear? Is it 19x10 or 8.5?<br>
<br>
The way you lower your car is perfect. That what I am aiming for. You said you used H&R springs. But the thing only drop for 1.3'. Using 19' rims.. it will leave about 1 finger of gap between the tire to the body. What did you do so you can drop your car the way you did?
G
Discussion Starter · #2 ·
With the right offset, the 19x10 should fit the rear with no problem at all. The alstadt I used was 9' but there was still a lot of space left to fit a 10' in there. I suggest you ask Luke at the Wheel and Tire forum for proper specs and fitment.<br> <br> I used H&R springs and changed to 1 pt pads. The pads can be bought from the dealer at $5 each. That's the only thing I did to get the drop I have now. Good luck !<br> <br> Frank
