G
FRANK, did you have to do anything to your 19" CL rims? A post said below that the CL and S (more)
rims wont fit on a CLK...I dont remember you saying that you had to do anything to the rims except have spacers mounted...Can you clarify this please?
G
Discussion Starter · #2 ·
I had Lorinser spacers installed that's why the hub...
had to be modified to accomodate them but if you use H&R spacers, you don't have to. Just bolt it on. Remember that I used only the 8.5 width wheel and not the 9.5.
G
Some guy Brian posted below that there needs to be machine work done on the bolt spacing?!?!!??
G
Discussion Starter · #5 ·
The only thing concerning the lug bolts that may need to be modified is the hole the lugs go through
The S class has 14mm diameter lug bolts while the CLK has 12mm, I believe. The bolt pattern for all M.B.'s is 5 x 112, there should be no modifications in that area.<br> <br> Tony
