9901 - 9920 of 9945 Posts
1978 280slc
Think I bought my AMG side skirts from that guy in SanJo, either way doesnt matter since engine and body kit are gone.
R/C107 Moderator
Needs manual ECU? What the fuck is that?
In this condition it is a parts car $1,500.00 tops.
Hey guys, new to the forum and have been trying to digest all of the valuable info I'm finding here on 107's. I found an ad local to me offering two 107's (73 450slc, 80 sl450) for 4k total. Both running but in need of tires. I'm going to check them out today with a checklist I found on here.
From what I gather, it looks like a grandparent passed away and they are selling off his belongings. The goal would be to fix one up and resell while keeping the other for personal use.
As long as they aren't completed rusted out and the motor/trans seem to be running fine I'll most likely go for them as I'm somewhat handy and wouldn't mind the project right now with everything going on. At least from the pictures it looks like the red SLC likely needs paint. Interiors also need some work.
All that being said, happy to listen to any advice or comments from the members here. Thanks in advance.
90305132_10163518629130012_6290770974191124480_o.jpg 91624920_1391474841040958_6433990601456222208_n.jpg 94619300_277881383232361_2474847360971177984_n.jpg 93620804_512179566356493_6974678253323681792_n.jpg 90238081_10163518613925012_4681887550938284032_o.jpg 90920035_10163518614285012_3586309735248297984_o.jpg
R/C107 Moderator
The fuel injection systems are different. The '73 is Electronic, Bosch D-Jet. The '80 is mechanical, Bosch K-Jet CIS. Both vehicles are subject to the front subframe failure which may have been corrected already. The '80 has the bound to fail Chrysler designed ACC II system.
Did some quick reading on the ACC system and looks like a modern replacement, although pricey, is the best bet. Thank you for that.
1987 560SL
I had a 1980 450SL like the one you are considering. Get rid of those chrome eyebrows over each wheel they attract rust. Since they are running consider a PPI (pre-purchase inspection). It was the best $133 I spent, the dealer was able to print out a limited service history. I looked at my old spreadsheets to see what the 1980 needed over time, so I'm pasting the chronological list here just for grins (and maybe a prediction of what might be in store). Major items were the timing chain and new soft top. Had no trouble with the HVAC charged with Envirosafe, maybe I was lucky. Here's what I spent over its two year history (about $5K) before an unlicensed fellow from Honduras totalled it:
used car inspection$133.00
Oxygen Sensor$ 13.71
Spark Plug$ 4.73
Hydraulic Hose$ 3.61
Fuel Filter$ 10.69
Hydraulic Hose$ 7.93
Oil Drain Plug Gasket$ 0.78
Belt$ 0.95
Oil Filter$ 5.04
Air Filter$ 9.52
Mercedes Benz 107 Owners, Shop Repair Manuals$19.95
CONVERTIBLE TOP LOCKING HANDLE PAIR$20.00
historical vehicle$28.95
Filter$ 10.13
Valve Cover Gasket$ 8.56
A/C Receiver Drier / Accumulator$ 6.71
Valve Cover Gasket$ 6.78
Tie Rod Assembly$16.76
Shift linkage bushing$5.90
Spark Plug$ 4.52
Shock Absorber$ 43.79
Wiper Blade$ 2.53
Wiper Blade$ 2.55
Headlamp Bulb$ 1.61
20 German fuses$9.99
High zinc 10W40 oil$13.00
Brake fluid$3.19
Seafoam$7.47
Degreaser$3.00
Seat Hinge Cover Right Lower$32.96
Power Steering Filter$ 6.50
A/C System O-Rings, Seals, & Gasket Kits$ 8.58
Shock Absorber$ 37.89
Idler Arm Bushing$ 20.99
Center Link$ 45.79
Steering Damper$ 24.79
Stabilizer Bar Link$ 6.98
shipping Rock Auto$21.67
full coverage$53.00
Febi sway bar bushing kit$24.13
Brake line 20 inch$6.44
plastic cleaner / plastic polish$17.61
Antifreeze$16.99
Gear oil 80w90$10.06
Distilled water$0.88
Dot 4 brake fluid$8.59
225/55R16$89.00
all wheel align$89.95
Dexron III tranny fluid$16.87
Camshaft oiler kit$12.15
Camshaft sprocket$27.00
$31.00
Folding Top Rear Weatherstrip$38.38
4 ounce oil charge AC$10.47
6 ounce refrigerant$5.78
Timing chain w 7 guides$149.95
Tranny pan gasket$8.98
Lug stud$3.09
Timing chain guide rail pin$10.00
Timing chain master link$9.18
Chain tightener$380.00
Rail pin puller tool$24.99
Woodruff key 2 deg offset$8.63
Double v-belts$21.38
v-belt, a/c$10.50
sealing ring$1.42
Subframe bushings Front$57.95
License plate frame$16.99
Ignition control module$35.00
Shift linkage bushings 2$4.56
stainless steel license plate frame$11.50
Ignition control shipping loan only$10.50
Blizzak ws70 sl w/ 2y road hazard$83.00
Voltage regulator$18.87
Alternator voltage regulator$9.99
Irridium spark plugs$7.09
Speedometer$102.13
Antenna mast$33.75
Instrument panel lights$15.30
Clip and snap ring for heater duct$1.00
AAV rubber hose$20.38
5 3/4 round headlamps$95.40
oil filter$2.98
thermostat$14.47
Oxygen Sensor$8.30
Wiper Blade$1.90
FOG LIGHT BULBS$1.72
Instrument panel lights$0.39
Air Filter$9.48
Halogen headlight clear$89.94
Dual 300 Watt Subwoofer$91.80
Soft top blue stayfast$296.67
Installation of soft top$779.38
brake pads, rotors, sensors, bearings, seals$158.15
self locking hex bolts and plates for rotors$51.02
AC Switch on reciever Drier$38.25
Door weatherstrip seal$27.00
Electric cooling fan$57.50
Hard top left and right window seals$40.56
Hard top right window seal, OEM$78.00
Soft top window weatherstrip left$30.75
Soft top window weatherstrip right$30.75
Windshield washer pump grommet$2.55
Windshield washer plug$1.65
Windshield washer tank cap$3.15
Windshield washer fluid resevoir OEM$158.10
Rear stabilizer sway bar link$11.63
Mercedes wood shifter knob$27.00
p.s. the price column is "each" so some stuff like tires are times four, stuff like spark plugs are times six, etc.
Spark Plug$ 4.73
Fuel Filter$ 10.69
Belt$ 0.95
Oil Filter$ 5.04
Air Filter$ 9.52
Filter$ 10.13
Spark Plug$ 4.52
Wiper Blade$ 2.53
Wiper Blade$ 2.55
Headlamp Bulb$ 1.61
Brake fluid$3.19
Seafoam$7.47
Degreaser$3.00
Center Link$ 45.79
full coverage$53.00
Antifreeze$16.99
225/55R16$89.00
$31.00
Lug stud$3.09
v-belt, a/c$10.50
sealing ring$1.42
Speedometer$102.13
Antenna mast$33.75
oil filter$2.98
thermostat$14.47
Oxygen Sensor$8.30
Wiper Blade$1.90
Air Filter$9.48
Comprehensive list! Thanks for that.
1987 300SL
Thanks Rowdie, stuck my hand up
Have to admit I very rarely browse the for sale section
Might have to change that
Same here, I might need to take a look there. Congrats Cousin, if for whatever reason it doesn't work out let me know please :D
I don't see any pics in the either ad? You'd imagine the one for $17k could warrant that.
1988 560SL 50K
I think that radio plate is aftermarket option, or maybe it's a fancy add on for hidden radio that's just now shown? It's weird that it protracts forward / is not flat with the rest of the central console and not shown on any close up pics. I recall (could be wrong) that MB factory delete option was a simple black plastic fascia.
Outstanding Contributor
450slc5.0cab 280sl5sp 280se4.5 500se+500slAMG +250seStkW108 350sl4spdX3 500secEuro
The listing says factory original in every aspect, but it’s clear that the VIN has option 519 for a Becker. So something seems fishy.
