has anyone taken out the glovebox to perform this....ls it easy ????? l purchased the 2 filters and would like to try this...Any suggestions ???? lt looks like there are a few screws on the top, is there anything else ??? Thanks............
Can you pls. share with a post?..I know that I found an online description with photos how to do it...
Yes..l did it tonight.....it took me all of 20 minutes to complete...7 screws in total.....Those 2 filters were pretty scary.........lt's nice to have, 2 fresh new filters in thier..........its easy and self explanatory as you go (if you're a lil mechanically inclined)
1. remove the fusebox cover on the side
2. using a torx screw driver, remove 3 torx screws on top(near the cd changer)
3. remove 3 torx screws on the bottom(where the footwell light is)
4. remove 1 torx screw near the fusebox.
5. remove the glove compartment lamp socket
6. voila!!!! you can now move the glovebox away and change your filters.
Did the glove box go back on straight after the installation?Yes..l did it tonight.....it took me all of 20 minutes to complete...7 screws in total.....Those 2 filters were pretty scary.........lt's nice to have, 2 fresh new filters in thier..........
I can't find that post and I'm interested seeing the pictorial page. Can you pls. post the link when you're safely back from your travel? ThnxI am on travel and do not have access to my computer but do a search on my posts. You will find I have linked a couple of previous treads to a pictoral page showing how to do the air filter change. If I remember correctly it is a Bosch page but I could be wrong. Have not done mine yet but it is coming up in a few thousand miles. The way my wife drives the car that will be in a couple of weeks!!!
l didn't have any difficulties............3 screws on top, 3 screws on the bottom and 1 on the side behind the fuse panel....l have the i-pod kit, so l had to unplug it..no biggie....Did the glove box go back on straight after the installation?
