1 - 13 of 13 Posts
1989 560sec 6.0L AMG & Renntech
These won't fit on an SL (R129). The bolt holes are too large diameter and the offset is completely wrong. These will work on any W140 though. They should fit on the W220 (spacers may be necessary).
1989 560 SEC - V-8 Kompressor - 95 E320 Estate
I have the exact set on my W140 with near new Conti's on them.. I have a backup set of wheels and tires, so if someone wants to throw me an offer I may part with them. I'm located in PNW (seattle area). Mike
Outstanding Contributor
450slc5.0cab 280sl5sp 280se4.5 500se+500slAMG +250seStkW108 350sl4spdX3 500secEuro
Bah. If someone figured out how to make them fit a 107 (highly custom 107), then I'm sure someone can figure out the spacers and special lug bolts for an r129 which has a generally higher offset.
Nice looking car. I doubt most people will go through that much work though. I should have said that the 129 would need to be converted to M14x1.5 studs then run spacers. That should do the trick if my memory serves right.
87' 190E 16V / 93' 600SL / 02' G500
Bolt pattern is good but bolt holes are cut for a 14mm bolt R129/107's run a 12mm. Will they work yes will they work properly...No
1 - 13 of 13 Posts
