881 - 900 of 901 Posts
1986 U1300L; 1976 U900 Cabriolet
Wanted: Clutch pedal assembly with helper spring. This is used in the bigger Mogs with the heavier clutch. Not sure whether there's any difference between the LHD and RHD models. Mine is RHD. Based in Sydney and have an office in Tulsa.
2612333
1969 Unimog 404S (404 114) 6cyl petrol - Ambulance
1969 Mercedes-Benz Unimog 404s Ambulance - $12,000.00
Licensed and insured in CA
Contact me at [email protected] 4,388miles. This is a rare to find Unimog 404 Ambulance in so original conditions. Engine, transmission, brakes, suspension, all in perfect running conditions and tested over Cleveland Mountain in SoCal. It just needs a light body and paint job to restore to original. Licensed and registered in California (no need smog check). Last weekend got a trophy for Best Military vehicle at Patriots and Paws carshow.”
The only thing this Mog needs, is some light sanding and paint, otherwise ALL runs great.
I can’t do that on the driveway in front of my house, obviously!
I will love to sell it to a new owner who can have some time to full restore it since this is a unique 99% all original rare to find ambulance.
This Mog is original from Belgium Army and Imported to US by previous owner to explore San Bernadino's abandoned gold mines.
The only thing not original is it custom battery box made to fit bigger batteries.
Paint is original from 1969
Clean California title under my name. License registration up today.
All records since I bought it but no records form previous owner one year ago.
All oils changed when I bought it.
Brake reservoir replaced.
All belts replaced.
Replaced one collapsed break line.
Flushed brake system, no leaks. Brakes pad and drums looks like brand new.
Gas tanks has been removed and cleaned.
Full carb services and tuned by a specialized company, all o-rings replaced for new gasoline type.
Two brand new batteries with 5 years warranty.
I have original color matching wire harness brand new in original box imported from Belgium.
All gauges, sirens, strobe light works.
Inside the ambulance is all in great and original conditions.
I have many parts brand new to be installed such join boots, heater fan, heater hoses, all switches labels, tools box, etc.
It has an extra front bumper with an arm and winch used to drop a person inside the mines holes (crazy ah!) I planned to use that arm and winch to carry the spare tire on the back of the ambulance.
Transmission and gear box in all great condition.
I have a complete spare wheel plus one more used tire.
ALL manuals you may need to fix and calibrate everything on this Mog.
Things I didn’t have time to fix:
The only rusted areas are 2 patches of ¼x3in on each side of the cabin corners. Minor other rust patches.
Doors vinyl windows are dry and crack. I got an estimate of $350 for both canvas. Windows are very easy to remove, so you can drive the Mog without windows. Some people put plexiglass.
Unimog videos
- Cleveland
- with Samurais
- driving in LA
1700L Doka
Complete 200 hp (est) turbo set up for om352.
Holset w1hc (rebuilt)
Exhaust manifold with egt port
Custom turbo to intake tube with boost port
IP pump (tractor gov)
Oil return tube
Oil feed hose
$3000 obo/trade
Unimog U1600/U1650 Rear spring set - OEM new
A pair of rear springs for Unimog U1600/U1650. Part number A4243240204. This may fit other models, but buyer needs to research and verify.
AU$995 (US$700)
Pickup Sydney or ship at buyers cost.
Genuine MB springs.
Turns out these springs are the 8.5ton upgrade for the U1000/U1200/U1250/U1400/U1450 plus the "L" versions as well as the standard springs for the U1600/U1650 and the "L" versions.
1966 404S (sold), 1963 S-P Haflinger 700AP
Not mine, but a UG3/40 trans just popped up on Kijiji in Quebec, Canada, suspiciously low price so buyer beware! One never knows though, might be a good buy.
Kijiji ad
1987 U1300L
Wanted:
1. New or gently used tires for a 1300L. MPTs or XM47s preferred but not exclusive. Ideally looking for a set of five but will entertain less, even just one.
2. Claas overdrive kit.
PM is the best way to reach me.
Danke
1700L Doka
OM352 Turbo Setup - Holset W1Hc turbo (complete internal rebuilt by Turbo Power with freed up turbine housing ;)) and custom adapter from turbo to intake manifold, valve cover (exchange),
exhaust manifold, IP pump: $2500 obo or interesting trade (working gears, amb box, other), plus shipping.
My seat of the pants puts thIs setup at about 190-200 hp. Nice upgrade!
84 U 900 Sold, 71 406 AG Sold
For Sale 2 Schmidt MF.3 Snow Plows, One is complete W Snow Deflector & One is for parts.
Includes new set of cutting edges & various parts. $5,550 for everything.
1971 Unimog 421, 1978 Case MB4/94, 1963 Land rover Series IIa,
Kijiji ad
I wrote the guy and went on and on with the guy but nothing came to fruition
WANTED:
I'm loking for SEE parts, or any part that will work in its place
2 hoods
1 engine cover for the inside
1 oil filter assembly
1 fuel filter assembly that sits up on the engine
2 passenger side doors
1 drivers side door.,
1 heater core
1 engine bay wiring harness. I think it houses a few relays. I have one thats bewen cut and the other is missing the relays.
Relays if you have them.
I need the fresh air vents for the drivers side dash area.
1 grill
1 headlight assembly
1 front passenger side fender
1 front passenger side foot step
Do you have any of the hydraulic tools?
Do you have any of the erxternal snorkel setups for these?
I also may be interested in a 12v conversion
A set of xm-47 tires.
I have All the hydraulic tools if needed. I also have a fresh air vent
