41 - 60 of 901 Posts
Unimogs
SBU Doors - NEW
FOR SALE:
Hi Guys,
I ended up with some spare SBU doors. 2 Fronts and 1 Rear Doka. Sheetmetal only, no regulators, etc. Drop me a line if interested.
Cheers,
Scott Ingham
1973 416 Doka, 1978 416 Doka, 1980 416 Doka..... Help me, I can't stop buying them!!!
TRUCK HAS BEEN SOLD! THANKS FOR LOOKING. 1985 U1200 with Schmidt MF3.4 plow and CASE counterweight on rear deck. Zero rust with only 13k miles. Has 24 speed transmission, Turbo motor, ROPS cab, front PTO, heated windshield and mirrors, three piece rims with conti MPT 80's with 95% tread, plus a bunch of other great options on it. Runs and drives great and in excellent overall condition! Call 585-377-7164 or email me at [email protected] for more info and photos. TRUCK HAS BEEN SOLD! THANKS FOR LOOKING.
'83 240d, '75 416 Unimog, '79 300SD
WANTED:
I am looking for a Unimog 416/406 shift boot in good condition.
I am looking for one that has five different shift leavers(Main-shifter 4-speed, High/Low, Reverse/Neutral/Forward, PTO, Four-wheel/rear-wheel/Four-wheel Lock).
85' U1300L Holset Turbo VA A/C, 66' Propane 404.1 rock mog, 1975 416 Doka, G500, Volvo C303
FOR SALE:
I have one underbed Jerry can holder from my 1300L I would like to offer for sale. It's the standard 1300 part that carries two cans and has a lock tab. Holder is in good shape, but needs to have one or two pieces of the flat bar straightened a touch to be perfect. I will likely do this before I ship it, but I always like full disclosure. No cans available. Lost one and the other is to rusty inside to use.
Make offer
FOR SALE:
I have four 11X20 drum brake rims from 406-416. The yellow rim is near perfect, as the other three will need new paint. Put these on your disc brake truck, and add over 6" to your track! Everyone would like an extra 6"!! Price is $250 each. Three still have tires on them, and they do hold air. If you want the tires I will throw them in for FREE!!! check out my site for more parts and info.
404.0 Doka, 404.1 resto-mod
U500 Doka Cab for SALE!!
FOR SALE:
I'm not sure how many folks on here are running UGNs but if there is interest - I am looking to make shop room!
I have a brand NEW, never mounted U500 Doka cab that I am looking to move. PM me for details... Good deal to whomever desires such a piece. Stored inside. It has 4 seats wide and matches the standard cab body lines. I believe these were originally designed for fire truck use. There are only TWO U500 fitted with these cabs in the states!!
PM or call Kyle at: (734) 272-3101
1991 Mercedes UNIMOG U1550 CREW CAB 4X4
SOLD:
Have a Re-Built 1991 Mercedes UNIMOG U1550 CREW CAB 4X4 in Excellant condition. It has 132,547 original miles on a OM366 diesel engine, 8 speed manual transmission. CLAAS overdrive unit, remanufactured injection pump, New turbo, Custom Aluminum radiator with custom under the hood inter cooler. New fast axles w/CTIS ports . New Front 15k and rear 20k hydro. winches both loaded with Amsteel blue rope controlled by a wireless remote. New Koni shocks all around. Entire dashboard was rewired with autometer gauges, all fuses were replaced with circuit breakers. equiped with carrier rooftop air cond.. Power windows, door locks, heated mirrors, back up camera, led lighting, and thermopane windows in the rear cab. also has a 5000 watt inverter. !SERIOUS! Buyers Only can contact through email or by calling at 708-860-2718 between 7am - 5pm, Monday- Friday $240,000.00
1980 U1000 Turbo...
FOR SALE:
Werner H38 (Hydraulic) and ground anchor assembly. Build documented on here. Currently on Ebay UK. Prepared to deal outside Fleaby for a Benzworld member, but not willing to pull the auction without a deposit.Happy to palletise if you want to supply the stamps, but it IS heavy.
Linky.
Unimog U1000 Werner Winch and ground anchor system. | eBay
63 Unimog ex-swiss 404, 59 220S W111#000925 from Ethiopia, 92 VW Corrado SLC
WANTED:
I'm looking for a 404 rear exhaust manifold for the M130 2.8 dual carb setup. I would prefer both sides and round ports but just a rear square or round will do. If someone has an extra laying around I'll turn it into cash! Thanks.
Unimogs
Michelin XMCL 380/75R20 x 5 Pieces
FOR SALE:
I have a set of 5 Surplus XMCL Michelin Ag tires that have never been mounted. Michelin tech specs here:
MICHELIN XMCL tire, the backhoe and telescopic handler tire
380/75R20 = 42" tall, 15" wide. Needs a 20" wheel. These make great Unimog Ag tires.
$2500 for the set of 5. Will not separate. Vallejo, CA.
FOR SALE:
FINALLY... A fiberglass hood worth buying!
These hoods are the best out there! They are made from a two piece mold process that creates a smooth finish on both the inside, as well as the outside. They have studs mounted right into the fiberglass to mount the two latches to! They have indents for all mounting holes including emblems and keyways. They are very stiff, light weight and fit great. Just add your own latchs and paint! This will outlast the rest of the truck!
Compare these hoods priced at only $450.00, to a new factory steel hood at over $1,100.00 plus the shipping from Germany.
These are in stock and ready to ship today!
All info can be found here. Unimog 406-416 Fiberglass hood
1975 404 Doka Unimog
Wanted 4 Shocks and 4 Rear Springs 404
WANTED:
I'm after a new set of 4 Koni shocks part number 84-1099 and 4 new rear springs for a 404. I'm in South East Queensland (Toowoomba 4350) so freight would be a consideration.
1971 Unimog 421, 1978 Case MB4/94, 1963 Land rover Series IIa,
My 421 For sale, Long Island,NY
FOR SALE:
1970 421 ag for sale. 4 Cyl diesel runs perfect! Has rust on cab but only some surface rust on frame. It has F&R PTO's, 4 way hydraulic system, air compressor with fitting on tank. 3 Way tipper bed and it all works, maybe not like a brand new mog but with a little TLC could be great. Has air lockers, 20 spd trans with Cascade. E-brake works perfect. I installed a new waterpump and rear wheel cylinders, I also had the fuel tank creamed and rewelded, it also comes with a spare 4cyl diesel engine. I also bought a brand new Good year Sure grip tire . There is a super heavy duty Pintle on the back aswell. This is a very rare machine and i know it is very rare and valuable in Germany. I figured i would offer it up to benzworld first. Feel free to call with any questions, Scott 516.456.0980
The 1st $8000 takes it
1975 404.0 DOKA
404 PTO Winch, MB type C
FOR SALE:
I have the COMPLETE PTO winch for a 404 (mounts, MB type C winch, prop shaft, PTO assembly, spooled with +/-70 meters of HD cable, lever....everything!). It is ready to install and use. Asking $4k.
I am selling this so that I can buy a true high compression head with a hopped up CAM so I am not looking for trades unless it is a souped up M130 with 9:1 compression and 140+ HP.
Phil
(505) 331-2120
[email protected]
