02 ML320
Do you guys think that a offset of +20 would sit the wheel too far out? Or should I go with the +35 offset?I kind of want it to poke out a bit but if it was too much then I won't go with them.Also whats the widest tire I can use other then 265?
Mercedes "M32"
ML55's come with 285's, I use them with a 33" diameter. I believe you will be fine up to 295's ... but I only know 285's will work first hand.
99 ML430
You can definately use a 295 but its gonna have to be like a 30 series tire. and they will stick out JUST a tad... nice look.
99 ML430
My fault Surbenzalot... was talkin about a 35 offset... apologies
02 ML320
SO would a +20 offset rub?The reason why I want to know is that the wheels I ordered are +35 offset but they now only have 2 instock and I don't want to wait for the other 2 to be made.Dont you hate it when sellers say its in stock but once they have your money it just magicly dissapears.Anyways he says he has +20 instock.Should I get them?
