1 - 8 of 8 Posts
1977 300D, 1980 450SL, Genuine Buddy 125cc Scooter
I dont even know how to turn them on LOL!, nah really though Im pretty sure theyre toast. Ive moved thaat switch all over the place..unless I have another switch.
anyway, without buying new ones first Id like to troubleshoot them w a multimeter yet I dont know which wires behind the bezel are for them.
basically i just wanna know how to get at the terminals w the lights in without piercing the insulation to get a reading.
thanks again!
85 300D, 84 300D, 05 Mustang GT Vert, 11 VW JSW TDI, 95 Del Sol, 88 IROC, 95 Villager, 04 Wrangler
Moved the switch all over the place, but did you pull it out? I've been fooled by my high beams being on as well, thinking the fogs were not working.
^ Yeah, turn the lights on low beam and pull the knob out toward you, they don't come on when the high beams are lit.
negative. Just tried that after seeing the reply(thanks!) I pulled it out and twisted it to the left nothing. there are icons there..like something should happen??
I also have a rocker switch to the left of the antenna switch that doesnt do anything. lol, neither does the antenna but thats a different post one day when I get the radio going.
twist the knob til the lights go on..then pull and NOT twist? I think thats what Im seeing. I feel like a dumbass.
Im going to check it now.
1984 300D
The fog lights are fed by the same fuse (F 11) as the right hand low beam headlight, so if the right side low beam headlight works, then the fuse is good. Did you check to see of both fog lights are burned out? If not, then you will have to start tracing the wiring with a voltmeter or test light. The wires to the fog lights are grey/green from the switch to the headlight connectors.
1 - 8 of 8 Posts
