1 - 8 of 8 Posts
2002 S430
The fog lights on my 2002 S430 won't turn on. The light bulbs (H1) are fine and I replaced them with new ones for good measure. My rear fog won't turn on as well and the light indicators for the fog lights at the switch doesn't illuminate. Is there a fuse to check? How can I trouble shoot it?
2000 and 2003 W220 S500
Is there a fog light error on the dash?
This might be silly, but you have to pull the knob for fog lights to work.
2002 S430
No fog light error, and yes I'm pulling the knob out one click for the front fog and two clicks for the rear and neither is coming on.
W210.265/2001, W220/S500/2000, Porsche 997 C2S/2006, GMC K1500/1992
It seems like the computer did not sense the the contact for the fog light when you pull out the knob. Trace the contact from the knob to the computer you may find the loose contact.
2002 S430
Any idea how to take the knob off to check?
Do you have the fuse diagram ? Usually it is hidden next to your spare tire. However, I check it out already, fog lamp use electronic fuse. That means it will not burn out. Research in the stickies, you should find some article about how to taken apart the panel above the steering wheel.
2002 S430
Thanks!
2000 s430
if you have to pull the switch for the fog lights to work, is there a juice cut of timer, so if you forget and I will..you woint get a dead battery...
1 - 8 of 8 Posts
