I am normally on the Gelaendewagen forum, own three Mercedes vehicles, having driven MB for 28 years or so.
My current concern is that on my 190E 2.3 with 94,000 ceareful miles, has begun to leave some foamy and oily substance in the coolant tank. The auto has never run hot, has had one water pump replacement, has had semi-annual coolant changes with MB coolant. I first noticed this foam last year, but noted that it was only a very modest amount, and actually thought it was related to the waterpump lubication I had installed - mostly to assure that the ph value would be neutral and reduce the chances of head electrolsis.
So, is this a sign of a failing head gasket? There is no noticable loss of oil and no water in the oil. I have flushed the overflow tank, and within 1,000 miles or so, there reappears more of this white foam. About 1/4 inch at the top of the tank fluid level.
I would appreciate anyone's thoughts about this.
Are failed headgaskets a problem with the 2.3 engine?
Again, the car runs fine, gets great mileage, and suffers no other symptoms whatsoever. I have even followed for over 100 miles as someone else drove - and watched for other signs of failing head gasket, i.e. exhaust emissions. Also, no white or blue smoke upon starting.
Thanks to anyone for your thoughts or insights.
Tom
Tom
