I've currently got a Neo car MP3 player with an FM modulator (http://www.partsexpress.com/pe/showdetl.cfm?&Product_ID=118444&DID=7) connected inline to the MCS antenna. The problem is that between NYC and Philly there aren't any stations that I can use (pretty much across the entire band) that don't have a strong signal creating lots of static. Are there any modulators out there that have a sort of filter to block out strong signals? I've found that disconnecting the antenna before the modulator works fairly well, but reconnecting the antenna underneath the rear passenger seat whenever I want to listen to the radio can be tedious...
Has anyone had any success with other methods like hacking a D2B converter to fool the MCS into thinking that it was the CD changer or somehow hardwiring an Aux input connector (I know I'm reaching with these two, but you never can tell).
