Hey guys - I have a 2005 SL500 with 100K miles and my friend-mechanic and I about to replace front and rear brakes (rotors/pads/sensors), motor mounts, valve cover gaskets, plugs, and lower ball joints. I figured that due to the mileage, and since it hasn't been done in the last 40K miles, I would change most of the fluids. Anything I should be aware of and/or NOT do? Thanks in advance....
SL55 C350 & ML320
Have them check the small pulley tensioner for the Serpentine belt.
Small cheap part that often develops a wobble and needs to be replaced but can cause big engine woes if it breaks.
Ian
