Hello Benz World Forum.
May I enquire wether anyone has had an issue with a Vito 108cdi that fluctuates or pulses in revs during idle and during take off through 2nd gear? Also around that rev count a rattle is evident going up through 1500-2000 revs and back down through same.
It is as if a bush bearing is worn and the shaft turning within it is eraticly bouncing from side to side,,,only at a less destructive level of volume and deeper in pitch. Almost like a water pump bearing but I have recently put its first waterpump replacement in six months ago. This is more under the middle of the engine not at the serpent belt end.
(A new alternator was fitted three years ago its not that.
I replaced the deisel pressure pump seals three years ago also and a oil and filter change a month ago,, just to update on recent mechanical history since ownership three years ago).
Thanks in advance.
Thanks in advance.
