1 - 1 of 1 Posts
Outstanding Contributor
1989 560SEC, 1989 560SEL, 1995 E420
I finally figured out how to keep the visor from hitting me in the head when I have it swiveled to the side and go around a turn.
I removed the visor from the car and discovered the swiveling bracket has a crack which reduced the friction between the bracket and the visor rod.
I found a thin wall nut that fit perfectly on the tapered portion of the bracket. By threading it on and tightening it down, the taper of the bracket automatically pressed harder against the visor rod. Friction restored.
Simple and effective.
Mike
1 - 1 of 1 Posts
