41 - 41 of 41 Posts
1984 300D
Good to know!
HA! I don't have any skinny friends that could fit under my car. Is there another way of doing it?
I feel your pain on waist line issue but I have long Arms.
If 3 1/2 inche
I used that technique you stipulated but it wasn't breaking loose despite suing a ball peen to shock it and crack the seal and PB Blaster. The dry ice on that bushing did the trick. The 3 prong puller I needed for the carrier bearing midway on the driveshaft and it came off nicely. On that one I used soap for the lube both on the bearing and in slipping the rubber sleeve over it as well
It worked. Heat on the drive shaft also might have helped. with out the Ice.
41 - 41 of 41 Posts
