54 401.101, 86 VW Syncro
I am rewiring my 401 with a new harness and all new switches. Things are going good until I hit the flasher relay.
The wiring diagram/parts manual call for 5443632, a 4 pin connector with pins of 49a/54, C2/K3, C/K2 and 15/49.
Can any wiring expert point me to a suitable replacement part?
I can find 4 pin relays, but not with the same numbers and my wiring expertise does not extend that far.
Thank you.
1957 Unimog 30, 1999 E320, 2004 E320
The harness in my 411 was hacked up pretty bad and I opted to also buy a new one and install it. The proper flasher was long gone in my truck and I was able to source a replacement through a local Bosch distributor in Toronto.
I think it took them a couple months to get it in, but it did arrive. This was a couple years ago now but the part should still be available, I'm sure it wasn't just the Unimog that used it.
You could also check with Westfield 4x4, that's where I got my harness and I would think he could find the right part for you.
Jason
